Built a hitch for a neighbor to pull a liquid fertilizer wagon behind a strip tillage machine.
Milled 5”x4”x1/2” angle down to 5”x3” for a tight fit in saddles then match drilled 1” holes on the Barnes drill press.
Used the Peerless hacksaw to cut 6”x8”x3/8” tube to length then jigged it up and welded.
