I did a line bore with my SB-9 using a boring bar that I fabricated from a 1" diameter, 1018 steel round about a foot long. As you can see in the photo, I supported the boring bar at both ends, but I understand that is not possible with a blind hole. In that situation I would try to keep the amount of projection from the lathe chuck as small as possible while still reaching the bottom of the hole.
The cutting bit which is visible sticking out of the top of the boring bar, is a broken end mill which I reground. It is held in place in a matching hole in the boring bar with a set screw. IIRC, I also ground a flat on the bit so it would keep it's orientation when the set screw is tightened. The bottom of the hole for the bit is threaded and there is another set screw which allows easy adjustment of the protrusion of the bit. This was not a difficult thing to do; I simply drilled with a tap bit through the boring bar and then enlarged the top 3/4s of it with a drill bit the same size as the end mill's diameter.
A feature of this boring bar which made the job a lot easier is the flat that you can see on the top of the boring bar. The cutting bit is in the middle of that flat and it allowed me to use a depth micrometer with a spacer that fit over the cutting bit to measure the protrusion of the bit. I took a reading when I first started boring and wrote it down. Then I was able to adjust the bit for additional increments for succeeding passes with micrometer accuracy. Again, IIRC, I hit my desired diameter (25mm) within 0.025mm or 0.001". The bore was also parallel to the sides of the block with similar accuracy.
The hardest part of the job was measuring the diameter of the hole without removing the block from the lathe. You can see a turned area on the right end of the boring bar: this has a known diameter. I subtracted that diameter from the desired 25mm and divided by two. That gave me the size of a drill bit that I could use for a rough measure. This needed a gentle touch to avoid deflecting the boring bar. I checked at four points at 90 degree intervals.
For the final diameter measurement I purchased an inexpensive pair of internal bow calipers and ground the jaws down to fit between that turned area and the final bore size. These were used to transfer the diameter to my micrometer so, with a good technique, I could measure down to several tenths.
With these measuring techniques and the flat on the boring bar I was able to easily dial in the needed changes in tool protrusion.
