Mini vice found while cleaning up.
  • Mini vice found while cleaning up.
    While cleaning up in my workshop, I again fell into the hands of a small vise that I built during my apprenticeship as a machinist.
    The part was only slightly tarnished, so I only removed the flats on an emery board.
    The part fits very well with my Pillar Tool.
    The spindle has a M 10 thread.
    The guide pins are 6 mm thick.
    The base plate has a thickness of 8 mm and the total height of the part is 24 mm.
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: Lehrzeit (1).jpg Ansichten: 0 Größe: 799,1 KB ID: 1995511
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: Lehrzeit (7).jpg Ansichten: 0 Größe: 863,3 KB ID: 1995512
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: Lehrzeit (13).jpg Ansichten: 0 Größe: 912,6 KB ID: 1995513 Klicke auf die Grafik für eine vergrößerte Ansicht  Name: DSCN1134.jpg Ansichten: 0 Größe: 634,8 KB ID: 1995514
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: DSCN1136.jpg Ansichten: 0 Größe: 930,5 KB ID: 1995515
    Many greetings from the southwest of Germany.
    Bruno
    http://www.mueller-bruno.de
    very nice
      Nicely made, good proportions. I like the double V.
      Only one fastener holds the fixed jaw in place, or it it pinned as well?
        I like that Bruno. Looks very handy.
          That things high quality and looks like it would come in handy for multiple sizes of square holding... Nice work.
            Looks like 1 screw in the middle and 2 pins on the sides
            Helder Ferreira
            Setubal, Portugal
              It would be dandy for holding square or round pieces end up. But that's pretty specific. No option for holding much else. You clearly made it with a very set use in mind. Is it just for square or round being held accurately on end?
              Chilliwack BC, Canada
                Nice design and well built Bruno,my Heinrich 30 8” Drill Press Vise built similar with sliding portion held captive in round shafts and it works great!
                  Don't you love it when you find something that's actually useful-
                    That's a real nifty vise. I particularly like the badge on the movable jaw. How was that done? Stamp? Engraving?
                      Nice work!
                        The fixed jaw is screwed in the center with a screw and additionally pinned with two pins.
                        Bruno
                          The logo was engraved with a stork's beak - pantograph from a self-made template.
                          Klicke auf die Grafik für eine vergrößerte Ansicht  Name: DSCN1001.jpg Ansichten: 0 Größe: 826,2 KB ID: 1996058
                          The vice was a workpiece during my apprenticeship as a machinist. I have attached the logo only now.
                          The vise lay dusty in a back corner of my workshop for a very long time. By chance, it fell into my hands again when cleaning up. I thought to myself, - The would do well on my Pillar Tool.
                          Bruno
                            The underside of the vise. I have added two screws to the one screw and the two pins.
                            Here I have also engraved my logo. You can also see my personnel number from my apprenticeship (903).
                            Bruno
