Fresh from my success with making a fixture for holding down parts to a plate in my bandsaw I realized that I could use the same idea for holding parts in my milling vise at an angle. This is overkill if only one part is needed but if we're doing a few it's something to keep in mind.
The bar I used is just a scrap of 1/4 aluminium. It could be done as a "T" shape to fit between the vise bed rails but it wasn't wide enough so I fitted two pins of 1/8 welding wire and filed flats on the outer edges of the pins until it was a light push fit to seat the jig between the rails. Holes will be drilled as needed and when I get too many holes in it I'll make a new one. This first go took about 20 minutes to make. So not a huge amount of time.
The pins are 3/32 welding rod. This is actually .095'ish so a nice push fit into the slight oversize holes made by a typical 3/32 drill bit.
Hope some of you find it helpful..... The pictures pretty well tell the whole story. I'll certainly find it useful for future projects. I just wish I'd thought of something this simple for setting up angles a long time ago....
And here's the hold downs all done and in place with the vise in the longitudinal setup which was the reason for doing these in the first place.
