As some of you may remember, I bought a ridiculously heavy electric forklift at an auction sort of by accident. It's a nifty machine but weighs a staggering 12,000 lbs+ with the battery but only has a 3k lift capacity.
Anyway, back in August or September it went on the fritz. The pump motor and hydraulics all worked fine, the steering worked fine, but the traction motor was dead - no relay pickup, nothing. I turned it into a lawn ornament through the winter but I really need to move some junk so I started poking at the forklift again a few weeks ago. I've got a manual for the EV-100 control card and the service manual for the forklift itself, curtesy of Landoll, and I decided the problem was the oscillator card - a logic board that controls the SCRs and relays for all of the forklift functions.
Thought briefly about trying to reverse engineer or repair the circuit board but then found I could buy a remanufactured unit for less than $200. I've got so many other projects now, I decided it was worth the money and the retailer's service department assured me that they had a direct drop in replacement for the card. My card was the first generation and was missing the "Y" plug for a handset or display (p/n IC3645EVS1 to be specific). They shipped me an IC3645LXCD1 SR card, a much newer version that has the Y-plug for a handset / display.
I hooked everything up and tried it out. It sort of works but it has very little power. In fact, I got stuck because I couldn't reverse through a *very* slight dip in the driveway. I was able to limp it back to its resting spot by manually closing the 1A and REV relays (i.e. poking them with a screw driver and walking with the forklift - a funny sight indeed). Plenty of power when the relays are bypassing the SCRs, so I don't think there is a problem with the traction motor or super weak battery (although the battery is not great).
Here's what I'm noticing with the new card:
1) Slow to pick up: The pedal has to travel quite a bit before the SCRs start to hum. I don't think I'm getting the "full torque" start feature.
2) I don't think I'm getting full 1A bypass, either. Particularly trying to reverse out of the dip, when I go all the way down on the pedal, I hear the microswitch close in the pedal sensor and there is a quick "clip clap" relay sound. For just a moment, I get a big lurch but then it goes back to a stall with SCR hum. I think the "clip clap" is actually the 1A bypass kicking in and immediately kicking out. I just get a momentary torque bump from the bypass.
3) When in stall with the SCR hum and no 1A bypass, quite a bit of heat is generated in the electronics compartment; more than when I manually close 1A to provide full battery power to the traction motor. I'm not sure what the controller is doing, but the panel and the cables get very warm / hot.
4) When driving (assuming I'm not stuck in a dip), the steering feels sort of gritty and weak. It feels fine when stationary - smooth and plenty of power to twist the rear wheel even though it's not rolling. Could be my imagination, though.
5) My forklift is a 36V unit, somewhat less common these days. Based on the manual, it sounds like the card should auto-range for 36V or 48V trucks, but I haven't been able to confirm this. Maybe my current draw - particularly when 1A closes - exceeds the safe threshold for a 48V truck so it goes into some kind of limited power mode...??
I'm guessing I'm going to need to buy ($550 YIKES!) or rent ($50, better) an LX handset to read status codes and change parameters on this card. Reading the manual, I haven't figured out exactly which settings could be causing the symptoms I'm experiencing, and that's what I'm hoping someone here can help me out with. The manuals are not super informative and, in some cases, they provide "helpful" information like "Listen to the SCR hum. If abnormal, do xyz" but I'm not experienced enough to know what it's supposed to sound like!
