Originally posted by RB211
View Post
limit switches on mill
Originally posted by Black Forest View Post
Mine are off by .0003 sometimes. I am not using the Z reference pulse. So I have to probe the part on start up. OK. Danke!
My mill has those same type of limits. They are pretty darned accurate and the life expectancy of a microswitch inside it is probably several magnitudes greater than the machine will ever see in actuations. Id stick with what's there.
- Likes 1
Originally posted by Black Forest View PostForgive my ignorance. If I was making more than one of the same part and I had to shut the machine down in between parts so there fore re-home the machine upon start up again I would then have to set part zero again also, correct?
The two principle types of homing methods are the original/preferred method that can be used where encoders are used on the M/C, the L.S. was only for initial reference, the machine would rapid to the limit, stop, back off slowly until the Z pulse on the encoder was seen, this was the most accurate way.
The systems such as Mach3 etc, use the L.S. alone and again the M/C will rapid to the limit then slowly come back to see the same limit again.
The one issue with using Proximity switches is where swarf may trip them during machining, unless some kind of protection fitted.
