[Doozer - you can skip this, I know that you think there's "Nothing wrong with backlash. If you think there is, seek help."]
In Part 1, BCRider had an idea for an adjustable nut, which I interpreted to be something like this:
Threading the 2 gives an accurate way of adjusting the back lash and the adjust-nut is held securely (the 20 tpi is arbitrary):
I was all set to do this on my mill table, but when I removed it, this is what I had:
That's not gonna' work. So I came up with Plan B:
There are other ideas that use a spring between the adjust-nut and the main nut. I don't like that because if the spring is strong enough to not compress under load, it will be putting that force on the lead screw's threads continuously.
In Plan B the adjust-nut is held rigidly with respect to the main nut and the distance between the 2 is adjustable via the differential-thread screws. The 1/4-20 and 10-32 threads give an effective pitch of 0.019 (53 tpi), so that fine tuning the back lash is easy enough.
(I hate it that I happened to pick 2 screws of unequal length - very amateur.)
I have it adjusted so that there is a couple of thou back lash at the ends and 0.015+- in the middle. Yeah, there's still back lash, but just feels so much nicer when I can take it up by swinging the crank 54* instead of 112*.
