Agreed about class D amps. I don't know if the amps I'm looking at are class D or not- but car amps never used to be class D. They were AB all the way.
My take on the design of an amp leads me to using a class D to supply voltage to the output transistors in a fairly standard amp, the common emitter type of design. Start with say 10 volts to the collectors, then maintain a fairly steady voltage across the output transistors as they swing up and down to supply the speaker signal. Class D could do this efficiently, while the amp runs in pure analog fashion. You could get away with using 50 volt output devices if you did it right.
