I'm sure that those of you that have a spindexer are like me and you've found that the indexing wheel gets in the way for some smaller detail jobs. For a good long time I've intended to flip my own indexer around so the collet was on the end away from the indexing wheel. About a week back I was doing another little tooling job for my shaper and I wanted to use the Spindexer for making a new auto advancing wheel for the shaper. But the indexing wheel was in the way....AGAIN ! ! ! ! So that was the final straw......
A quick CAD session later and I was back in the shop drawing in hand and hogging down a lump of 3" round bar. Nice big boy chips were coming off the Amazon sourced TCMT inserts that I was "trying out" for about 6 months now. These being used on the cheap kit of holders that I bought about 10 years ago. They original inserts were horrid things but these new ones are working well as long as I do things the way that carbide needs them to be done. This handful is a 100 thou DOC so 0.2 off the diameter. The motor was grunting deeply during this. I would like to have gone with a faster feed rate and got the chip breaker thing going but that would have dimmed the lights and stalled the motor. Still, I'm happy enough with this sort of swarf coming off a 3" bar....
The result of all this carving was this ring.
Next up was centering the indexing wheel to bore it out to fit the adapter ring. I didn't get pics of the setup because it had me going. I centered up the middle hole then started to run the lathe only to notice that the ring of indexing holes was running wobbly. So things got complicated as I had to use a dial gauge with an ID adapter and zero up the ring of holes. That ring after all being the important feature. Anyway it got done and the center was bored out and a score line marked for drilling to mount the plate to the adapter ring.
And here's a sneak peak towards the finish.
