Originally posted by BCRider
View Post
Hot roll work hardening like SS
There are usually plenty of the straight shank carbide tipped masonary drills left over from when SDS took over to sharpen into very good drills for that ****ty steel. Their advantage is cheapness and not being brittle like solid carbide drills are.
- Likes 1
Sometimes you have to slow down to go faster. In a perfect world, the heat should be carried away with the chip. If you're putting heat into the work piece you're rubbing/causing friction. Either by running the spindle too fast, or by not feeding enough. Coolant/oil helps tremendously too, to carry heat away, and lubricate the cutting edge. For most people it's running to high of an RPM for HSS. It's a very common mistake I see over and over. SFM and chipload #'s exist for every material/tooling combination known to man. I know most manual machinists fly by the seat of the pants most of the time (I do too), but it's helpful every once in a while to re calibrate yourself to ideal parameters when results aren't what you expect. All that said, sometimes the material is just ****, and you have to adjust.
- Likes 1
Originally posted by old mart View PostThere are usually plenty of the straight shank carbide tipped masonary drills left over from when SDS took over to sharpen into very good drills for that ****ty steel. Their advantage is cheapness and not being brittle like solid carbide drills are.
Originally posted by Bented View Post
There is always a very short dwell at the bottom of a blind hole as the drives decelerate at the bottom then accelerate in the opposite direction, have never found this to be problematic.
Originally posted by BobH View Post
Ok, you got me. How do you sharpen a masonry drill to cut hard steel?VitŮŽria, Brazil
- Likes 1
It's always hit and miss when you're machining a steel made for architectural purposes - A36 is made to a strength specification and not at all to a machinability specification. Same for rebar. Both are usually machinable because (I suspect) they hit the low end of the spec but when they hit the high end of the spec or have some odd inclusion all bets are off.
I once had a chunk of 1 1/2 3/16 angle that needed half a dozen 4-40 holes. All but one went in fine, the last cost 3-4 drills and a couple of taps. I finally drilled it out to 1/2", TIG'd in a 1018 plug and cleaned it up both sides with a Foredom *then* drilled and tapped the 1018 with no fuss.
- Likes 1
I've never understood the "inclusions" thing.
Most of the rebar etc is said to be made from remelt, but that's the point..... It was melted, and then poured out at least once (if they use a strand casting method) which should melt everything in the charge, and mix it up reasonably well.
The stories about finding a ball bearing unmelted in a piece of steel make little sense. A small piece like that should have easily been melted when the rest of the charge melted, it is unlikely to remain solid and distinct. Maybe if it is not steel, but something with a significantly higher melting point that got into the charge, then it might survive through the process.
I suppose it is "possible" to have areas of different composition. One way is if it is first poured as an ingot, then re-heated and rolled without "cropping" the "segregated" areas of the ingot, then there could be some wildly different areas with certain elements in totally different composition from the rest of the ingot, and they may get rolled out in part of the material that is processed.
Some elements tend to not "freeze" with the main part of the ingot, and show up in higher concentration (segregated) in the last parts to freeze Mostly those are cut off and thrown in with scrap in a later batch. I suppose if the remelt operation does not do that, there may be areas that have different properties. I just have a problem with the "I found a ball bearing", or "I found an unmelted nut" etc.
