Further analogy of the diaphragm type pump (again if you have one)
these pumps get weaker and weaker by nature - they start out very supple, then as with most all other rubber components get crystalized,
so with something that's pretty old you can bet this effect has taken place, it results in "micro pumping" as there still some flexibility but not much - so if the check valves are still operable you will get small pulsations in fact just fractions of what once was, but once it catches can be enough to keep the engine running at higher RPM's because they all "add up"...
again if your system is gravity fed please disregard - but keep it in mind for other engines that use this system....
