Martin Model makes a nice set of castings for a manually operated shaper and I thought I might post some photos of my progress. Shapers are fascinating things and certainly off the beaten track nowadays. However, once in awhile you might really need one for internal keyways, gears, and other odds and ends. In my case I wish to cut v-grooves of about 92-93 degrees into small pieces of brass that will easily fold up into miniature brass "boxes" of about .25 inches square for brazing. These will become the ends of the many wooden arms required to reproduce a replica of Jefferson's first polygraph or copy machine - something that no one has seen for 200 years. Yes, two of his later machines survive, but his very first has been lost to history.
I have made great use of a similar Strong Arm build by "Stepside" posted here several years ago (he has also recently been super encouraging by email!) and I thought I'd post some similar photos for anyone else contemplating the project and offer similar help and/or suggestions. It's a bit involved but the castings are absolutely superb. I started by skimming the top to allow for accurately machining the bottom.
The traveling slide is a bit tricky. It helped me to write out the steps for proceeding.
Current state:
About those t-slots: I have discovered t-slot cutters are like most machinists, home and professional. They're quite sensitive and have too much to do!
Here is where convention requires I mention no connection to Martin Model other than very satisfied customer....
Regards, Charles M
Current state:
Regards, Charles M
