Greetings fellow machinists,
I'm thinking back to my first post here about 15 years ago and it was a question about a South Bend Heavy 10 lathe and Lane answered it almost immediately and I fixed my problem. It was a mater of not staying in back gear and Lane told me to tighten up the set screw on the back that has a spring loaded plunger behind it. That fixed it in less than a minute.
Fast forward about 15 years and I ran into a guy that has a heavy 10 but doesn't have any idea how to operate it so I told him that I'd assist him in getting it going and teach him the basics of running it. Today I got it running and cutting but there is a problem with the feed. It has the knob on the carriage like my South Bend's have had that you turn clockwise to engage the carriage feed. But this one doesn't stop feeding when you turn the knob counter clockwise. It doesn't feed at hard as if it was engaged but if you don't hold it back it will keep feeding as long as the motor is running and the leadscrew is turning. And the carriage shows it. It's the most beat up carriage that I've ever seen from being fed into the chuck. My guess is that people would stop the feed but it would keep feeding and hit the spinning chuck.
So my question is, why isn't the carriage completely disengaging? Could it be just too much crud behind the apron? This lathe looked like it was last cleaned during the Kennedy administration. Zero oil anywhere on it. I thought before I start tearing the apron off I'd check in with the experts here.
I'm planning on working on it again tomorrow so if anyone has the answer it would be most appreciated.
Thanks,
Thanks,
