I knew the gap bed lathe would pay off at some point!
Relax. He was moving the tailstock to use the center to hold the part while centering. The crane was still holding the part and the lathe doesn't move without the chuck protection
The leadscrew is so long that it has some supports that are moved around so it doesn't sag and the carriage has a little stand on rails so that the operator rides along with it
In my case, it's not the lathe that has the gap, it's the operator.
I had considered buying a brake drum lathe to refurbish and use for large diameter items. But I don't have room for it anyway. That could be a blessing-
