Originally posted by Bented
View Post
Also, the tool rounds BOTH sides as it cuts off. If the separate rounding tool does not do both sides, then you need THREE tooling changes. If you make a tool to round both sides, you may as well make it do the cutoff as well, since it spans the area required to do both.
I actually considered that approach. However, I rapidly realized that I could do the work faster, and get better results as far as burrs, if one tool did it all.
Using the combination tool (something well known to any turret lathe folks) means one operation, NO movement of the carriage, one tooling station used, and NO tooling changes. The tool also has the minimum burr creation. It's not ALL about doing it in one step, it was also about eliminating second ops.
By runnng in a cutoff tool after the rounding, there is a good chance that the cutoff will raise a burr. And there goes the advantage, as you may need a second op to deburr.
I don't see the "easily accomplished" as being "easy", nor useful, if it adds tooling changes, second ops, and time to the operation.
That is the difference in approach between the mindset for manual operations and the mindset for CNC. The CNC can do the multiple changes, and handle the whole task with a de-burr, although it does take more time even there, than one tool for the cutoff and rounding at once would.
So the CNC folks can be relatively liberal in the adding of tool changes and operations, since they are all handled by the CNC, and possibly in a totally hands-off manner.
