I get a free mill!
I made some modifications to the back gear housing. I drilled and installed a grease zerk to the back side like you see on some other mills for greasing the back gears obviously. Then where the existing oiler was I put a groove in the base of the gear housing to channel oil from the oiler to the back gear bearings. Just a couple easy and quick mods but I am satisfied that everything will get lube now in the upper end.Andy
I realized something after watching some videos. There was no quill skirt in this mill. From what I gather it is to keep junk off the top side of the quill. How crucial is this skirt? Should I get one and install it or just forget about it?Andy
