Gravity Auto-Feed Jig for (Powermatic) vertical bandsaw
  • Gravity Auto-Feed Jig for (Powermatic) vertical bandsaw
    Powermatic offered a gravity auto-feed option on their variable speed vertical metal/wood bandsaws.
    This one had only the foot feed bar remaining. So I improvised an alternative, with an adjustable vise
    fashioned from an old hold-down/pallet fixture plate, instead of the cables and pulleys dragging a
    material guide plate.
    The damper was an add-on to make the foot release un-latching and end-of-cut unexciting.
    That’s pretty neat. Never saw that before.
      Well done.
        Very accurate work!
        I just wonder of it's a straight or T-slot in the table. If it's not a T-slot, what prevents carriage from jumping up and down or tilting if cut unattended?
        WI/IL border, USA
          Great looking modifications, well done.
          We have the same Powermatic saw at work but it's missing most of the mechanism. I'd love to fix it like yours, but am afraid it would just get wrecked like everything else. It's tough to make anything nice around here, as there are a few individuals that love wrecking things as if it were a sport lol.
            Great solution! I have an old DoAll that also used a gravity weight. Unfortunately mine doesn't have the weight or wheels. I'll have to make notes on your idea so if I get time it would bge a good project. So when do you slide/change the weight position?
              MichaelP: Is just a straight slot in table, like any other fence/miter rail. The vise plate is reasonably heavy, and cutting forces are downward...I have not
              noted any jumpy behaviour, but I also don't cut things unattended. For thin stuff should consider some 3/8" tall support material (the thickness
              of the vise base plate) on the opposite side of the blade. I have only done a couple of tests with rigid stuff unattended, more to satisfy myself the
              damper eliminates any end-of-cut weight crash excitement. Have not even used the flush mounting pusher block I made.
              Asallwey: The weight slide choice I guess you play by ear. I do not expect my weight is near what Powermatic provided, but my fulcrum point is certainly
              farther out. I consider this mod just an aid; it relieves some tedium of pushing big stuff, and you can still add manual push or pull as conditions warrant.
              I originally conceived of welding a bracket on the one weight to carry another weight plate, but so far single weight seems adequate. YMMV.
                Very nice addition wbc,a good note on the Push&Pull when needed.The cable&pulley setup in first pic allows power feed to be used for Contour Cutting.
                  Yeah, I Saw is one of the better ones.
                  Powermatic is top notch in the wood section. I do Knot ,wood work good,, so I dont ,
                  You have to see that joke (Puns) in there?? I do it all the time here they are Lame. This is half the joke..
                  Love that Machine. If I had the room.. JRJR
