Originally posted by Richard P Wilson
View Post
And, it WAS a "lathe". Perhaps more of a "lathe shaped object", but it functioned, and I used it. Yes I got pleasure from using it. Yes I learned a lot.
HOWEVER.... I am not sure that the OP is looking for that. He says he has determined that the 109 is the best choice for what he does. It is to be assumed (pretty much actually stated) that he thinks it will be good for his indefinite use. It does not appear that he wants "a learning experience".
I do not know his experience level. If he is very familiar with lathes, has long experience, well, he can get the best it is capable of doing. I am surprised in that case that he would select it, but he has to "do him".
Say or think whatever you want.
Having owned a 109, and having used it over a considerable period of time, I would advise him to get a used minilathe, 9 x 20, or similar, and avoid the 109. Those others are clearly not without faults, many shared with the 109. They are about the same size, but with somewhat more capacity.
However, the 109 is functionally incomplete, lacking basic functions. The minilathe and 9 x 20 are functionally complete, with essentially all the basic functions of a lathe present. Yes the 109 "can be used". The minilathe etc are far easier to use, with many fewer problems and issues affecting every single use than the 109 has.
The 109 has many deficiencies which come out in daily use, in terms of no dials, fast speed, limited tooling, general weakness, very limited capacity, and the probable need for rather extensive repair before practical use (mine required a lot)....... Yet it is considered the best? One has to ask "WHY?".
It seems that for similar money one can obtain a used import machine that is better built, better designed, and better featured, with considerable support from a user-base. Why go for a machine that is much older, generally in bad shape, less well designed, less well featured, with minimal support? One frankly designed only to look like a lathe and be as cheap as possible (THAT design goal was spectacularly achieved).
Again.... do you want to dick around with a machine that not only may require repairs, but also, by it's basic design and quality, does not justify spending time and money to do the repairs? Or, do you want to do the work for which you need a lathe?
Why not both?
Well, you do you, I'll do me. But having actual extended experience with that particular machine, not just armchair theory, I think I have very valid comments. And opinions. Note that I tried for the best accuracy I could..... I was not "just aiming to get close". I found it so different from a more "complete" machine as to be night and day.
I sold my 109. But, I refused to sell it to a couple potential buyers. Why? Because I KNEW it would not do what they stated they wanted. The ultimate buyer simply looked at it, never turned it on, and paid me on the spot. He gave no idea what he wanted to do with it, so I had to assume he knew what he was doing.
We do not know what the OP really wants to do. He mentioned aluminum.... If he is ONLY making small pens, maybe... but even there I expect that he will run into basic limitations very quickly. The minilathe and the 9 x 20 both can easily accept a pen body in the spindle, which the 109 cannot. And one need have no fear of using the chuck, their spindles will not bend.
AS I said, I do not disagree about the "learning experience". However, the 9x20 and minilathe can give much the same, and have vastly improved capabilities. Once you learn, you can continue to use them productively without inordinate compromise.
I hate to see someone heading for a collision between his expectations and reality, one possibly affecting his continued enjoyment of a nice hobby. Especially when there are many choices that appear far superior per the info we have, yet need not cost more or take up more room.
