Great printable color coding labels for tools
You can buy heat shrink tube for hand held label maker. Print, shink, done
- Likes 2
I did a project once (twice actually) where I needed to identify wiring at both ends. Same sort of idea- I used colored stickers and wrote on them, then used clear heat shrink to keep them in place. Not only did that keep the stickers in place, it also kept the sticky goo from oozing out and making a mess.
Originally posted by Dave94Lightning View PostOr you can laser mark all your tools
At one point in my long, storied career, I tried to color code wrenches.
Ended up using tape. On top of the obvious problem, (the tape came off) there are two hidden issues, the standards issues Paul and Linnl alluded to.
With no standards, blue can be half inch in one set and 9/16 in another. This leads to confusion, even without apprentices who need to keep their last name written down.
And the fasteners themselves need to be the same color as their wrenches.
Don't even get me started about remembering the colors.
For fractional sizes you could just do everything in 64ths with two colours even if it could be reduced. ie mark a half inch as 32. Or have a band like the tolerance on a resistor to tell which denominator is used. Though for some like say 47 would obviously be in 64ths. You could also rely on a bit of common sense as you would have some appreciation of size anyway telling you when something marked as 27 is 27/32 or 27/64.
Originally posted by Baz View PostLook interesting but you are clearly not into electronics or you would have used the resistor colour coding.
- Likes 1
- Likes 1
Originally posted by Dave C View Postgelfex, I've been trying to find these with no luck: 2016 labels for $6 on Amazon. Do you have a link for them?
Another site I frequent does not allow commercial links, I get out of the habit, and don't want to be seen as an Amazon shill!
Originally posted by genea View PostNow all you need is color coded socket head screws.
Originally posted by lynnl View PostA few years back I bought a nice new set of ratcheting box-end/open-end wrenches having both metric and SAE flavors.
I wrapped them with some durable colored tape to enable me to easily distinguish them. ....proved largely an exercise in futility. I can never remember which color is which!
Looks good. I hope they stay put.
I have seen color coded sets of sockets and always wondered if there was any standard. I know Xcelite makes nut drivers with color coded handles. IIRC, red is 1/4". But it would be nice if the various manufacturers had gotten together and settled on some standard colors. And perhaps some way of marking English and metric ones.
