I'd like input on using a large ballast from a HID lighting system as the power source for a spot welder. The one I came across is 20 lbs and 1000 watts. I'm confused about the multiple input taps and the huge size of the secondary. Any help is appreciated.
HID ballast for a spot welder
Originally posted by SLK001 View Post
Then a 1000 watt transformer should be able to do what you want.
The OP's 20lb, 1000w doesn't seem right. A 1200w MOT is only 5lb or so. The MOT's duty cycle is way less than an HID's ballast, but still.
HID ballasts have extra steel for a partial magnetic shunt, etc. They are not like a standard choke coil.CNC machines only go through the motions.
