Take an appropriate sized hex nut and bore a recess the depth of the washers thickness and .003/.005 bigger than the diameter. Cut completely through one side with a hacksaw and 1/3 through the opposite side.
When the nut is back in the lathe Chuck it will pinch down on the washer OD so you can drill or bore it. If you’re careful when releasing the Chuck, the nut will remain in place because you allowed that little extra on the diameter and the washer will come right out.
