number of poles on a 3phase motor?
Originally posted by jwmelvin View PostWhat's the base speed of the motor? ~3400 rpm = 2-pole; ~1700 rpm = 4-pole4357 2773 5647 3671 3645 0087 1276
"There's no pleasing these serpents"......Lewis Carroll
- Likes 2
Originally posted by skunkworks View Post
Umm - we use American RPM on this forum....
How interesting..... since BF just happens to be in a place you may have heard of, called Germany. it's in europe, where they don;t do things the same way...............4357 2773 5647 3671 3645 0087 1276
Hopefully there should be a motor plate. 2 pole 3000rpm, 4 pole 1500rpm, 6 pole 1000rpm 8 pole 750rpm , approximate figures @50 hz. Without the plate, you could switch it on and check the rpm with a digital counter, or somebody will know what the field windings look like.
Take no notice of boasts about mains frequency, just ask them how heavy a ton is or how big a gallon is.Last edited by old mart; 05-05-2022, 02:58 PM.
- Likes 1
I think the only reason the VFD wants to know is so that when it displays the motor rpm, it does so correctly. It does not put anything different down the wires to the motor whatever pole value you give it. So guess if you have to, run the motor at 50Hz, measure the actual rpms and see if they agree with the display on the VFD.
- Likes 3
More important than the poles as the VFD does't care except to show the correct speed on the display, that motor has a dc brake powered by the same lines as the motor. To run on the VFD you need an external relay with permanent supply to power the brake controlled by one of the VFD's control relays (most have 2) with the external brake parameter activated. Most will ask at which output frequency should the brake be released/engaged.Helder Ferreira
Setubal, Portugal
- Likes 1
Originally posted by Noitoen View PostMore important than the poles as the VFD does't care except to show the correct speed on the display, that motor has a dc brake powered by the same lines as the motor. To run on the VFD you need an external relay with permanent supply to power the brake controlled by one of the VFD's control relays (most have 2) with the external brake parameter activated. Most will ask at which output frequency should the brake be released/engaged.
The motor is 1500 rpm.Location: The Black Forest in Germany
