The black part with the 3 screws/wires look like a half bridge rectifier used to power dc brakes to me. I think there is a label on the side
number of poles on a 3phase motor?
Originally posted by Black Forest View PostI just called the factory and the brake is 220v AC.True AC motor brakes are 3 phase devices that look like flat motors.
Helder Ferreira
Setubal, Portugal
Originally posted by skunkworks View Post
Umm - we use American RPM on this forum....Peter - novice home machinist, modern motorcycle enthusiast.
Monarch 10EE 1942
Originally posted by Peter. View Post
They say ignorance is bliss. You must be incredibly happyLocation: The Black Forest in Germany
- Likes 2
Your best bet is to assume it is 4 pole, the commonest type, program that in and when the motor is started check the rpm. If it is 1500 approximately, at 50 Hz then you are good to go. Reprogramming is easy if the guess was wrong.
I would play safe with the brake and dissconnect it before setting up the VFD.Last edited by old mart; 05-06-2022, 06:49 AM.
Originally posted by Black Forest View PostFor me it makes no difference what the brake actually uses for power. I only care about what I have to feed it!
Helder Ferreira
Setubal, Portugal
Originally posted by Noitoen View Post
I just wanted you to know that you need that part and a relay to operate the brake case you have problems in future. I would still like a picture of the side to confirm if I'm right or wrongLocation: The Black Forest in Germany
The 220v holds the brake off. When no power is supplied to the brake it is on. So I assume it is an electromagnetic brake. The brakes for the 3 axis have 24v DC brakes.Location: The Black Forest in Germany
DC is used because you get a stable and silent magnetic field. AC will always vibrate at line frequency and that's why ac cores on relay coils have a little copper bar one turn short to reduce this vibration.Helder Ferreira
Setubal, Portugal
