Originally posted by J Tiers
View Post
We have a problem......................
Drilling a twenty foot jump shot is VERY satisfying though….
Back to the lathe. Some shafts/screws are better removed WITH the apron. In which case you need to block under the apron while detaching the saddle and moving it aside.
Often lead screws are attached to the gear box with cleverly concealed taper pins or alternate booby traps.
Every brand is different, you’ll just need to gently work through the process.
If it were me, I would remove the apron from the lathe and completely disassemble it getting all the critical shafts gears etc.out of the way. You may have to make up some kind of jig to hold the broken part in the correct position for welding. As far as I know, because is a casting it should be preheated before welding.Larry - west coast of Canada
