Gents, found an angle grinder jig ( intended for tile cutting but needs must) that makes chamfering for vee prep on steel plate a little more pleasant and a lot less rough, and anything that helps getting nice even chamfers on steel up to 3/4” without sweat I like, as I said it’s intended for ceramic tile using 125 mm angle grinder but works nicely with a thin cutting disk on Ali or steel plate, also noticed a clever app for extruded Ali strut and 2 sawhorses in the shape of their bench I never thought of
its limited in angles but a bit of file work to the angle slot increases the min/max as you need, graff do a carbide continuous rim metal disk that’s thin too, not cheap but outlasts abrasive on Ali and steel, in fact a saw blade for metal can be fitted and handled safely as I don’t like saw blades or the like on a loose angle grinder
https://youtu.be/zDbvIWaae2s
might make life easier as it looks fabri cobblable if you don’t fancy buying one
you might need another project! Lol, fol what’s fol, fart out loud
mark
mark
