In the process of “restoring” my first Bridgeport. Step pulley 1hp 9x42 table. It included an Enco vise (8in) with swivel base. The vise seems to overwhelm the table with excessive overhang. I’ll be doing mostly small hobbiest type projects. For those that have similar machines is there a “sweet spot” in terms of vise size that is more appropriate? I know this will be very subjective - just curious what others thought. Thanks
Vise size recommendations
I have a Kurt 5 inch and a Kurt 6 inch vise and both work well , but the 5 ( no longer made) is my favorite and there is very little it cannot do .
I also had a 3 inch B & S with rotary base and never used it . the 6 inch is hernia territory so I need help with it when needed
One thing you need to look at is how far open do you need the jaws ! Obviously the 6 opens more but there are techniques to handle that
Both vises have extra jaws. Tall ones and thinner ones of Aluminum .. very important to maximize the range of work .
My mill is a step head BP with a 9 x 32 table Remember , the bigger the vise, the more it sticks out beyond the table , both in front and on the column side
Having a 12 inch knee helps there
Rich
I also have a 4 inch vise given to me and it's from India..What a piece of crap.
Green Bay, WI
- Likes 2
I’d go with 5” myself, it’s rare to need more than 5”, 6” is just bragging territory imho, I’ve got by with a worn out 4” for years ( whoops I’m down in the gutter again)
funny story, a technician came into the control room in the early hours on the weekend and blurted ( he often did) my girlfriend saw me in the nip for the first time last night, she laughed and said “ who do you think your going to satisfy with that” at which he immediately replied” me of course, don’t care what you do”
mark
- Likes 1
Originally posted by mwill135 View PostAll good points. The 8in is a two person minimum move and even then it’s awkward. It can with the m
Downside is already mentioned, it sucked to move. The other downside of that particular vise was it was just shy of opening up to 8”. More than a few times I had to take the movable hard jaw off to fit a work piece in it.
Originally posted by Toolguy View PostOn the 6" Kurt and copies, you can move the jaw plates to the outside of the fixed and movable jaws to hold something up to 15" on top of the jaws.Southwest Utah
- Likes 1
All Kurts have that ability to expand opening.
Also by only moving one jaw outside, the the stationary or moving jaw becomes a parallel for mounting work ( because the tops of the jaws are precision ground
RichGreen Bay, WI
- Likes 1
Originally posted by oxford View Post
Yes, I have done it before. You could do it on the 8” vise I mentioned above. Down side is if you have to drill any holes in the piece you are most likely going to hit the vise. It does come in handy for some things though.Kansas City area
