Just throw out my two cents: My lathe had no lube specs with it whatsoever, so I've experimented a bit:
for a while I used hyraulic oil (I have a lot of it for my tractor)--honestly probably one of the best things I have tried
for a couple years I used straight atf--yes its very thin, but has a lot of good cleaning properties. it you''re diligent about lubing your ways, it works.
At some point, all I had on hand was gear oil--that worked too.
Recently I tried a gallon on bar lube, which to the best of my knowledge, does not contain sulfur (its perfectly clear). I've been real happy with that, though when finally get around to scraping my lathe, I'll be buying some proper way oil.
