Originally posted by jmm03
View Post
Another Packing Joke
Originally posted by rdfeil View Post
But officer, your eyes look glazed. Have you been eating donuts??? Sorry, I couldn't resist 😇.....
- Likes 1
https://www.kissthisguy.com/donuts-m...sheard-322.htm
USA Maryland 21030
- Likes 1
Well, now I understand why I have blue eyes- all those donuts. Actually, I love that song- thanks for posting it Paul.
- Likes 2
I have received orders from McMaster that way, but NO packing of any type. Just small, heavy items bouncing around inside a big box. And several of them escaped through the holes they made in the box.
Grrrrrrrrrrrr!Paul A.
Amazon has patents on methods to determine optimum box size for an order. It's a multidimensional problem that includes- Maintaining a stock of boxes - More box sizes -> more cost
- Time to pack a box - Lost throughput if Andy Amazonworker has to try fitting the order into the box several different ways before it fits
- Dense packing of filled boxes - The current box sizes are chosen to make more likely that the boxes will stack nicely.
- etc
- Likes 4
Dan, your example (4 by 6 by 9 object object in an 8 by 8 by 12 box) would make a lot of sense. BUT the photo in post Home is no where near that ratio. His order is more like 1/2" x 1", x 24". It will fit sideways in the box that was used. And there would still be an awful amount of wasted space.
And, other than the OEM's paper wrap, there was no effective packing material. So his order was easily subject to damage even if it stayed inside the box which was not guaranteed.
Yea, I did notice the very few inflated "balloons". They were just totally ineffective. The empty space in a package needs to be completely filled with something. This is more true as the weight or density of the contents increases and steel bars are very dense.
I have been on the receiving end of far too many damaged shipments. Some of them running into the thousands and tens of thousands of dollars to correct. I even have a stack of bent steel parts that were a minor item attached to a very expensive item. The OEM had to replace all of them. And it was all due to the packing. The box was too small and the packing material was not enough to prevent things from moving around. The truck drivers really did know how to bounce it to maximum effect.
Originally posted by Dan_the_Chemist View PostAmazon has patents on methods to determine optimum box size for an order. It's a multidimensional problem that includes- Maintaining a stock of boxes - More box sizes -> more cost
- etc
- etc
the weight of the package or the amount of space it takes up in a container, truck plane etc.
JL.................
Originally posted by Paul Alciatore View PostDan, your example (4 by 6 by 9 object object in an 8 by 8 by 12 box) would make a lot of sense. BUT the photo in post Home is no where near that ratio. His order is more like 1/2" x 1", x 24". It will fit sideways in the box that was used. And there would still be an awful amount of wasted space.
I think it might be possible, and advantageous, to have some custom box-making machines that could quickly make appropriate size boxes based on dimensions of the product(s) being shipped. They could be sized so that they could be stacked in a manner as to maximize storage space and allow for easy identification and handling. Long thin items like rods, pipe, and tool handles could be shipped in cut-to-size cardboard tubes. But I'm pretty sure this has been considered before, and the present system must have some valid reason for its existence. Maybe the forestry products industry gives incentives for using more cardboard than necessary, at the expense of trees and proliferation of trash in landfills and oceans. Fortunately, cardboard is very recyclable, but not too many people or businesses do so. Maybe the major shippers should also take away used packaging materials. One place where I worked said that they had to pay a considerable fee to have their recyclables collected, and it was cheaper and less hassle to just cram it in the dumpster.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
