I’m an avid reader on this forum, but don’t contribute too much from my lack of experience. I have a Logan Powermatic 11x 24 lathe (2 hp motor and VFD) and occasionally get requests to machine aluminum round plate stock.
Example - 1” thick, 6” diameter round plate stock and needs a 4” inner diameter machined through.
My question - What is the best technique for removing all of that material? I have drilled a 1” hole through and then I used a boring bar to remove the rest of the material. Takes quite a few passes to get there. Has anyone used any type of groove tool and just cored-out the majority of the stock?
Just looking for the forum’s expertise. Any suggestions are appreciated!
Thanks, Rob
Thanks, Rob
