I'm finally going to do something about the crappy sheet metal base on my MSC 4x6, it's just so flimsy if I have to move the saw. I remember somebody posted an improved DIY base a while back, and I'm sure others have done it too. I want to steal your ideas!
Show me your DIY base for your 4x6 bandsaw
Originally posted by jimsehr View PostThis is how I beefed up mine. And I use the inside to keep extra saw blades
and other saw accessories.
Originally posted by junkaddict View PostJust a base, but it stiffened it up pretty well.
I wish I could think of a clever way to do it with welding 3/4 gas pipe, I just cut out like 30' of 100 year old gaslight lines!Last edited by gellfex; 05-11-2022, 11:21 PM.Location: Jersey City NJ USA
I TIG welded my frame to make it more solid and dealt with the bad headaches of the smoke it gave off. Eventually gave away the saw, I now use a portaband on a Swag base to make it a vertical with foot operated switch. Still kicking myself for not aggressively going for that DoAll bandsaw from the auction that I got the 10EE and surface grinder from.
Yes the stands are indeed flimsy, they will almost fold in a slight breeze.
I had some pieces of 2.25"x2.5"x 1/16" angle stock on hand and simply cut it to fit on the insides of the legs.
Used some small bolts and washers to tie it all up and oh what a difference! The 1/16th inch stock at first thought seemed too light, but when combined with what was already there it made for a very rigid and sturdy stand that while at first glance appears as it came from the store, is indeed a very stout stand.
While there I also put in a heavier bracket for the axle and increased the wheel size slightly from the mickey mouse wheels originally installed. Not off road capable but adequate for a concrete surface.
A couple pieces of scrap 2X4 and about 15 minutes effort improved my bandsaw frame considerably.
https://gadgetbuilder.com/BandSaw.html#BandsawLegsLocation: Newtown, CT USA
Rudy K cut a piece of plywood that just fit inside the base at the bottom. IIRC he said it stiffened the base immeasurably.
Here is what a buddy and I did back in the for our 7x12 saws: http://nwnative.us/Grant/shop%20arti...ase/index.html
Originally posted by ed_h View PostI added coolant capability, which I raremy use:
It's all mind over matter.
If you don't mind, it don't matter.
