What is this?
  • What is this?
    Any ideas?
    You may only view thumbnails in this gallery. This gallery has 1 photos.
    Clothes pin, for air drying the laundry? Round part goes around the clothes line, flat part pinches the fabric. Allows the clothes to move more in winds. The clothes don't fall off the line as much as clothes pins that pinch the line.
    SE MI, USA
      Out of focus picture
        It's a grostling iron
        George
          For drying wet prints.
            Vacuum connector for a Buchner funnel aka vacuum funnel, funnel sits on top of a flask with a side arm to the vacuum supply, pump or tap injector via rubber hose
            Though it’s classy bronze one, the recess in the thing looks vacuum hose ( like stainless hoover pipe)
            guessing btw
            mark
              I'm with boslab, the undercut circular area looks like a low pressure/vacuum flange clamp for fittings similar to tri-clover clamp.
              It's all mind over matter.
              If you don't mind, it don't matter.
                Birth control device.
