Is EVERYBODY vandalizing public restrooms?
  • Is EVERYBODY vandalizing public restrooms?
    I want full sets of TORX BITS, short, medium and long. I want them to fit DIRECTLY into my 1/4 hex cordless impact driver. All the ones that I find have holes in the end for Torx SECURITY screws. The only place that I ever see these is in public restrooms. Are there really that many restroom vandals? Where can I buy some non vandal torx bits? Edwin Dirnbeck
    These are used in all sorts of places, lots on electronics. The non-tamper-proof bits should be readily available pretty much anywhere I'd guess. Have you gone to the local hardware store? I recommend Wiha if you want high quality.
      I’ve seen the tamper proof screws on industrial e-stops. I can’t remember if they were torx or hex.
        Dude, they put a shackle and padlock on the toliete paper at Waffle House ! ! !
        What does that tell ya ? (We don't have them up in yankee land. So dirty but
        so good ! ! !)
        -Doozer
        DZER
          These work too. Available at most Ace Hardware Stores.
Name:	Screen Shot 2022-05-17 at 11.55.25 AM.png
            I hardly think that the presence of the hole will affect the usability of torx bits, the strength lies in the circumference not the middle.
              Won't affect it in terms of fitting the fastener, but it will definitely affect the ultimate strength of the bit. That's determined by the cross sectional area. The hole removes a fair bit of that. Probably will still be fine though for most things shy of impact use.
                A friend's wife worked at a Sizzler Steak House where they had an unlimited buffet, but some customers (usually fat women) would try to hide gobs of food under their dresses and leave with it. When confronted, they got angry, and retaliated by going into the rest room and sitting (or jumping) on the sinks until they broke off the wall mounts, creating a flood and expensive damage. Anti-tamper screws would not be effective for that level of vandalism.
                I had a harder time finding tamper proof Torx tools that would fit into deep recessed holes, where the 1/8" hex bits and drivers would not work.
                USA Maryland 21030
                  Good God, really?
                  That's pure crazy !
                  Thanks for the mental image though.
                  -D
                  DZER
                    Sounds like they needed to be put down like a rabid raccoon
                      Wow, you have a Sizzler? I loved them, but haven't seen them in a long time.
                        Seems to me that the so-called tamper proof socket head screws are just about worthless. First, you can get an assortment of bits with both kinds of bits for well under $10. I have several. And second, a small screwdriver or punch or almost any steel tool that will fit between the central pin and the walls of the hole will EASILY break that pin off and then any standard, non tapper proof bit will work.
                        Totally worthless!
                        The other style that Tungsten dipper shows is a bit harder to defeat, but any file, including nail files, can quickly change the geometry so a standard screwdriver tip can remover it.
                        The idiots are smarter than the idiot proofers.
                          Tamper proof screws are a lot like the cable lock I use on my wildlife cameras. A cordless Dremel type tool with a thin abrasive disk will easily cut them but most would be thieves don't happen to carry one along. Same with the tamper proof socket head screws, the bits are readily available but you need one along with you to defeat them. Most vandals don't carry them. Security through obscurity works for computers the same way, easily defeated if you have the tool.
                            https://apexfasteners.com/fasteners/...53963212217e8b
                            Sole proprietor of Acme Buggy Whips Ltd.
                            Specialty products for beating dead horses.
                              https://www.mcmaster.com/7396A81/
