I picked up an old camel back drill press for scrap value. Does anyone know what speed ranges these were designed for? I looked up 1- 1/2" in mild steel, 242 rpm. On the low end I'm thinking around 60 rpm for driving hole saws. High end 1000 max. rpm because of plain bearings? I got this because I don't feel comfortable drilling large holes in the Bridgeport.
Camel back drill press
Describing a drill press as a Camelback leaves the field open to hundreds of machines. Can you narrow the field down a bit with a picture or a mfg and model number? I do agree with Ohio Mike on the shaft speed if it was a OH belt drive machine.
lg
no neat sig linenear Salem OR
Originally posted by larry_g View PostDescribing a drill press as a Camelback leaves the field open to hundreds of machines. Can you narrow the field down a bit with a picture or a mfg and model number? I do agree with Ohio Mike on the shaft speed if it was a OH belt drive machine.
lg
no neat sig line
If you know exactly what machine
he has, how much more succinct
advice would you be giving ? ? ?
--DDZER
Drilling is the first thing that comes to mind but I’ve found a low rpm ( think it was 48? On an Elliot 4e, anyway it was low) are brilliant for hole tapping, reaming and counterboring without chatter, I don’t remember using a carbon steel drill even though they exist, a big range of speeds is definately useful, I was sticking 3” holes in with a Forstner bit earlier, low speed was useful even if they can run faster.
mark
lg
no neat sig lineI just need one more tool,just one!
