Laser etching dials.?
  • RSG
    I have a 30W fiber laser! Great tool for deep engraving and etching but unless you have a need for one on a regular bases they can be an expensive dust collector 😆
  • macona
    I could be wrong, but I suspect the optics (lenses or mirrors) to go along with that diode array would cost more than the array itself. All of that light output must be focused on a single spot - or at least a large percentage of it. That is not a trivial task.
    Thats what the direct diode laser systems on the market do, arrays of diodes focus through a transform lens, through a dispersive optic and out an output coupler. They are doing it with IR but there is no reason you can do it with other wavelengths,.
    Originally posted by macona View Post
    ...<snip>...
    You could do this with blue laser diodes too if you had a big enough diode array. But that would be one BIG array. I have cut copper with a green DPSS laser.
    ...<snip>...
  • macona
    If I remember right the Hardinge HLV-H's we had at work had some sort of white plastic that the increments were engraved in and then filled with black paint.
    I have some of those lacquer sticks for markings. They work pretty well.
  • Doc Nickel
    Even a cheap "K40" Chinese desktop engraver will do most plastics, and fairly easily.
    And there are sticks of a sort of solid lacquer paint that are basically meant for filling in dial hash marks. Make yourself a ring out of white Delrin, engrave it in a K40 with a cheap eBay indexer/4th axis, fill in the marks with the lacquer stick, and you're set!
    Doc.
  • Baz
    Wasn't there some detail on here by his Lordship, John Stevenson, on his work with laser etching?
    While on the subject of handwheel dials I like the Hardinge ones, creamy white with black numbers. Is there any source of two layer engraving substrate in tube form? Engraving white plastic and filling, or painting and filling seems a bit 'cheap'. I can't remember if the Hardinge ones are flush or recessed engravings. If the latter the colour choice makes sense as dirty cutting oil wiped off maintains the contrast while any other method shows the dirt.
  • macona
    While wavelength does make a difference on how well it works it is power in the end that matters. If it absorbs less of a specific wavelength you just need more power or smaller spot size. There are infrared direct diode lasers that cut steel
    The machines we build at work use 500w CO2 lasers that end up at around 20-30w at the surface but at a super tiny spot size to blast holes down to about 30um.
    But yes, nothing you are going to find under ~$1500 is going to do much damage to metal. I have gotten a 80w CO2 to mark carbon steel but it was not pretty. I have seen people use the cheap Chinese fiber lasers to cut very thin metal. I am hoping to be able to cut thin metal with the laser cutter I am building. We will see how that works out.
  • Doc Nickel
    None of the infrared or blue-diode lasers, the cheap ones, anyway, will engrave metal. It's not a "power" thing, it's a wavelength issue.
    As noted, there are sprays and other coatings that can be used to make marks, but basically what the laser is doing is "spot welding" the spray to the metal- kind of like a precise, limited-are powdercoating. It's still just a coating- some of the better ones are surprisingly durable, but they're still basically just paint.
    An option is to make the dial in aluminum, have it anodized, and then use the laser to engrave the lines. The cheap "K40" type desktop lasers mark anodized aluminum nicely. You'll need a 4th axis or indexer to do it, though...
    If I were making new handwheel dials- and I recently have - I'd make the marks mechanically. Something that absolutely can't wash off or rub off.
    Doc.
  • macona
    Originally posted by Noitoen View Post
    For a fiber laser etching metal like that it costs more than 20,000 Eur. With some help from a spray at 60+ Euro a can, you can engrave some metals with a cheap 40W Co2 laser like my Chinese K40
    If you want a quality one, sure. But there are cheap Chinese fiber laser units out there that are not that bad. Some will even do color on stainless (has to do with pulse width and rep rate).
    https://www.alibaba.com/product-deta...242fj7PqzE&s=p
  • vpt
    The laser he is using is probably a fiber laser. They start at a couple thousand and go up. Another option is blacking the steel and using a CO2 to mark it or use something like the ceramark in the other video. There are only a few lasers that will mark metal directly.
    A $300 laser off amazon or anything that will fit on a 3D printer will not directly etch metal.
    Sometime ago I went down the road of wanting to laser engrave things as well. After reading and asking questions this is the result I got as well.
    You can paint parts and engrave the paint easily with a cheap laser but it takes a lot of money to do anything straight onto metal.
  • Doozer
    Shureline (the watch lathe people) will laser engrave dials for a fee.
    Never used them, just saw their service on their web site.
    -Doozer
  • Noitoen
    I've heard that plain old mustard will help engrave metal with a Co2 laser but I haven't tried. I use the laser to make brass or stainless steel nameplates by using mat black auto spray paint as a mask drawn by the laser and then electro etch it with a small power supply and salty water. It doesn't more than a few minutes to remove a significant amount of metal that is then covered in paint to bake some shiny plates.
  • Noitoen
    Originally posted by SLK001 View Post
    You, too, can have a laser engraver for the minuscule price of $6,200 US.
  • macona
  • Randy
    Amazon shows several around $300. Just for flat work. Indexing around a cross slide dial, for instance, would be more complicated. Clough42 has a few YouTube videos in depth about laser etching.
