Why are two piece jaws a CNC thing? It seems to me they'd help us, too...
Two Piece Jaws
They are not strictly for cnc machines, there is no reason one can not install such a chuck on a 100 year old lathe.
Many modern lathes employ hydraulic chucks which often have limited jaw travel, serrated top jaws may be moved in small increments to accommodate part size.
I have them at home, and several of the shops I've worked in have two piece jaws on every manual lathe. Very handy indeed. Soft jaws machined to size make for very precise chucking - akin to a supersized collet chuck. This is especially useful for high precision on multiple piece runs or securely holding irregularly shaped parts.
- Likes 2
There are several advantages to 2-piece jaws. One of the biggest is that the chuck and jaws rarely get separated from each other when sold by the family of the deceased. There are lots of chucks floating around with only one set of 1-piece jaws.It's all mind over matter.
If you don't mind, it don't matter.
The common type of two piece jaws used on manual chucks are slot and tenon. They will have a minimum of 2 screws, normally SHCS type per jaw. The advantage I would take advantage of if I had that type of chuck, is with a mill, you can make soft tops in steel, aluminium or even plastic. I would think they take about the same time to change round as taking one piece jaws out and changing them. I do have a manual chuck with serrated jaws, an early type used before power chucks became the norm for cnc lathes. It is primarily intended for soft jaws. The other difference between otherwise identical size chucks is that two piece jaws overhang the front of the chuck body about 50% more than one piece ones.
Well, YES! I have a SB-9 and have a chuck with two piece jaws on it. It works great.
I never even thought to question it's use on a manual lathe.
Originally posted by Jammer Six View PostWhy are two piece jaws a CNC thing? It seems to me they'd help us, too...Paul A.
Originally posted by Jammer Six View PostIf I'm shopping for just the jaws, where would I look? I only see two piece jaws with chucks out there, but I'm sure that's because I don't know where to look.
I have bought numerous sets of used soft jaws for chucks with one piece jaws, and some are well used up. These can be milled down and threaded to hold soft top halves. The ones I have done this to have larger tops which can be bored to hold delicate items.
Buying any sets of extra chuck jaws is difficult due to the sellers often not knowing how to measure them properly and also just quoting the serial numbers which are only useful to match a set. The chuck makers often only make proprietry jaws which only fit a particular model. An example of strange practice is the lightweight 6" four jaw independent that Pratt Burnerd used to make, the jaws had either ACME or square thread forms.
The relevant standards are ASME B5.8-2001 (you can find a pdf of it online) and IS 15248:2002 (Indian Standard, available at the internet archive. It is a direct parallel of ISO 3442:1991). Bonus points for anyone who compares the dimensions in the ASME (inch) and ISO (metric) standards.
