Not really looking for advice-just found this situation interesting….
Had a coolant pump motor on a seldom used drill press “loudly hum”. Smelled bad, didn’t spin. Pulled it out of the tank, unwired, ohmed it, freed it up, seemed ok. Wired back up, loud hum, thought “I need to find a replacement “.
6 months pass-
Tried it again, it runs, but smells bad. Tear it apart:
In last picture you can see a few windings imbedded in the melted remains of a plastic “housing” where the connections were made.
Obviously, something got hot and melted the housing. Maybe, because the motor was stalled because the impeller was stuck.
All I really know, is I need to rustle up a different pump or motor.
6 months pass-
