Noga Top Adjust or Base Adjust?
  • Noga Top Adjust or Base Adjust?
    While searching for a dial indicator lug attachment device, I came across some really cool Noga magnetic base/articulating holders. Anyone have one of these things and do you recommend the top adjust or base adjust model?
    I love them, but only worked with Base adjust
    Rich
    NOGA, the only way to go !
    Green Bay, WI
      I have a NOGA copy made in India, and the weak part is the top adjust not being tight enough to stay where it is set.
        OK, will order the bottom adjust version. By the way, where you guys buying items like this - Amazon? MSC? Zoro?
          Buy one of each -- you will use them.
            Linear indicator, base. Test, top. Base adjust is better built. Also but the more expensive of the mid-size model if that is the one you are going for. It is way beefier.
              After procrastinating I ordered the small unit, forgetting that I wanted the base adjuster. So I made one. I got the idea from a YouTube video from NYC CNC, and simplified it for a manual build. It's kind of nice to have both adjusters.
ID:	2003450 Click image for larger version
ID:	2003451 Click image for larger version
                Here's one I built.
ID:	2003465 Click image for larger version
ID:	2003466 Click image for larger version
                  ANyone know why the restriction on shipping NOGA bases ?
                  From the MSC website
                  View Compliance and Restrictions
                  This item cannot be shipped via air carrier.
                  Rich
                  Green Bay, WI
                    I think the mid-sized base adjuster is the one I am going to order then - I believe it is p/n DG10533. Looks like best deal is on fleabay.
                      Get the MG if it's not too big. It's the heavy duty version vs the regular duty. It is a bit bigger, so best for 14"+ lathes.
                      https://www.amazon.com/NOGA-Heavy-Du.../dp/B001VY1DYQ
                      vs
                      https://www.amazon.com/DG10533-Stand...dp/B001VY07VQ/
                      I bought the light duty for work and heavy duty for home. The heavy duty is built like a brick ****house and much stiffer than the other. Bigger works better for my big lathes too. The end adjust is prone to falling apart, this one is much more robust.
                        I use mine exclusively with test indicators. Top adjust is my choice for that. It’s a 3 step process where you set the base, place and lock the indicator then fine adjust the indicator. Never made sense to me to go back to the base for step 3. You are already at the top. As tomato coupe said buy all the sizes you can afford. I have one import and it’s definitely not as stable as the nogsa’s.
                          Just a note on the clones.
                          I bought one each of the small and medium size clones. I took them apart and tuned up the locking rods and cones so they lock with little torque on the knob. From that side I'd say they are good value since they are easily tuned up. But the downside is that the indicator clamp on the clones is pretty cheezy soft alloy. They do work but the grip is a bit wobbly.
                          I don't know what the actual Noga arms use for the clamping end but if they are a proper steel or even a better made aluminium clamp that grips securely then between the better material and not needing to fettle the pushrods and cones that the actual Noga brand arms are not a bad deal at all even despite being twice or more the price. You choose.
                          Chilliwack BC, Canada
                            Stefan built an indicator holder & used top adjust. IIRC, he didn't like the bottom adjust because there was too long an arm between the adjuster & the indicator. Which makes very fine adjustments tricky. https://www.youtube.com/watch?v=37TLOf3GWwM&t=1550s
                              Rich
                              Pretty sure its because of the magnets, i think magnets above a certain power can only be shipped ground
