Pallet of shim stock, good price?
I guess I go through mine a little faster than some. Not a whole lot faster mind you.
I use a bit more of the thicker sizes as brackets and plates for smaller and model related projects. So .010 up to around .040 is a desirable commodity in my shop.
Chilliwack BC, Canada
Originally posted by Doozer View PostI recently came home with probably 300 or 400 horizontal
milling cutters. All from 4" to 8"+ diameter. All basically sharp.
I have no idea what to do with them. I have 3 horizontal mills
and really probably will only ever need 30 or 40 cutters to last
me a lifetime.
--Doozer25 miles north of Buffalo NY, USA
Shim stock is not all that expensive when purchased by the roll. Cold rolled steel is usually between $10.00 and $20.00 for a 6" x 180" roll. Used equipment dealers most often sell it for between 40% and 50% of the retail price. I bought a couple dozen new rolls from .0005" to .020" from an equipment dealer for about the same price more than 10 years ago. It does come in handy, but I'm sure I have more than a lifetime supply. Attempting to sell it on eBay or other online sites would be more time consuming than it's worth.
If you have a use for it the price is great. If you're going to purchase it and make an attempt to sell it good luck.
Originally posted by nickel-city-fab View Post
Maybe keep what you need and scrap the rest? Clean steel is crazy high right now, and you can easily make more than what you have into it.
- Likes 1
