It's raining solidly today. So I made some keys.
They are very simple flat plate keys for a cheap lock in a case I use a lot. It came with two and I lost one a couple of years ago. I wanted some spares. So since it's a very simple "suitcase" lock I was able to make some from flat plate.
But then it came time to drill the key ring holes in the keys. And the vise grip hold down I often use for this sort of thing was fighting me and the wing nut simply did not want to go onto the stud..... So I stopped and made the simple hold down shown below in about 30 to 40 minutes. It's something I've intended to do now for quite a few months.
It's good just over 1.5" of height before the front portion is at the wrong angle to apply pressure at the toe.
Material is 1/4" HR mild 1.25 wide by 4.3 cut from a piece of scrap plate. A 27/64" hole was drilled for a 3/8 stud. It was bent in the vise using a piece of 7/8OD black pipe as a bend radius mandrel with some assistance from my 20oz ball peen. Care being take to get the plate square to the pipe.
The hole crushed closed a little plus I also filed in some angles along the length of the hole to form a sort of X shaped slot to permit the angles of the stud as shown to cover the range of height adjustments.
And after rounding the toe and heel with a file or some belt sanding and the bend is made do check for any rocking and correct it with some extra filing or grinding to get the clamp to sit evenly on the flat and on something around an inch thick.
