I've been noticing a trend that technical accuracy in catalogs is starting to slide. Sometimes it's just a typo, but other times it's a failure to understand accepted nomenclature.
Two examples:
I was shopping for a few accessories for the new lathe, a collet chuck was one thing I was after. So I needed to shop by spindle mount ,not sure which camlock spindle the lathe has, I went to the company website and looked it up-
Description says D1-5, but that's not right, D1-5 has six pins, this only has three, turns out it's a D1-4. The manual has the correct spec, but the webpage is wrong. Luckily I caught it before return shipping became an issue.
Second example: Nationally known distributor for pipe fittings, old company, but with new hard copy and web catalog. Pipe tees, malleable iron, threaded. They come in three configurations -straight meaning all three ports the same size, lateral reducing and main reducing. Catalog uses the same picture of a lateral reducing tee regardless of which type. So look at the description and order from that. Well....
3/4 x 3/4 x 3/4 is a straight 3/4 tee
3/4 x 1/2 x 3/4 is a reducing lateral
3/4 x 3/4 x 1/2 is a reducing main
But that isn't immediately obvious to the average warehouse stock clerk and the pictures all look the same, so order 80 each 3/4 x 1/2 x 3/4 and get 80 each 3/4 x 3/4 x 1/2 instead. Then spend a half hour on hold trying to explain this to inside sales. The factor that exacerbated that experience, is that the older staff that knew all of this and had it right previously, have either retired , or quit and went to work for another company.
Two examples:
