Gentlemen here is a brake pad for my Polaris Ranger EV that cost several thousand dollars! Yep, just made out of brass not gold. This parking brake pad is what prompted me to get off my butt and convert my mill to CNC so I could machine this pad. The parking brake pads are not replaceable. You have to replace the entire parking brake assembly. It is not possible to buy just the pads only the whole assembly at over $200! Absurd design. It is a very wasteful design. So what does any self-respecting home shop machinist do you ask? He tools up in order to make said brake pad himself of course! Yes I know I could have used a rotary table to make the part on a manual mill but my wife didn't know that!!!!!!! It took me a lot of time to convert my mill to CNC and a lot of learning on how to do the conversion and learn how to actually make the program to mill it. Countless questions on here and the Centroid forum, etc., etc.. But I showed the Polaris company didn't I.
They won't be messing with me. The brass actually doesn't work well as the brake pad. Too slippery. Please don't tell my wife. The brake assembly is a disk brake design with the disk mounted on the drive shaft coming out of the transmission with the "calipers" next to it. If I tighten the brake cable enough to actually hold the buggy on a hill the brake squeals when driving. No squeal no holding power. Now I have to figure out how to fix this problem. Any suggestions on what machine I need to buy to solve this problem?
