I recently upgraded my lathe from a piston BXA size to a genuine Aloris CXA wedge toolpost. It works well with a couple of Aloris toolholders and some Yuasa toolholders (about 2/3 to 3/4 of handle travel at toolholder properly secured). I have a few older import toolholders and they secure nearer to the end of travel. Now a few weeks ago I bought an import boring bar holder and a 4 pack of toolholders - these are the ones where the block is longer (a feature I like). Even though sellers give their toolholders different brand names; based on the form; the P/N itself; the P/N size, font and location, all toolholders appear to be from the same manufacturer. Of the 5 recently purchased toolholders, for 4 of them I can swing the locking lever full travel and I can slip the holder up off of the post. On the remaining one, the handle resistance (as the wedge begins to do its job) just begins as the handle reaches its end travel. I am not able to slide this toolholder up off the post but I am convinced it is not properly secured.
I have had a few import tool holders that were a bit tight on either the AXA or BXA piston toolposts - where the lever had to be just right to be able to slide the tool holder onto the post. But I have not experienced the holder being too large. Then again I was not using a wedge tool post.
I presume there is no adjustment as to the qty of wedge action on an Aloris wedge tool post. Correct? While there might be some wear on the tool post (bought used), the Aloris and Yuasa toolholders are secured at 2/3 to 3/4 of handle rotation. I suspect these holders would work just fine on a piston toolpost. I started the return request w/ eBay and the seller is singing the blues since the return shipping is no subsidized. I just wanted to make sure there is not something I could be doing to improve the engagement. BTW, I have attached the images I supplied the eBay seller for the boring bar holder comparing the Aloris tool holder to the newly purchased boring bar holder.
