I 'm in the process of attempting to fab a CNC Router table and trying to get some of the concerns I have to overcome visualized before I go that particular route...
Goal- 2 x 2 square tube needs to be fly cut on the top @ 48" long for the linear rail to fit flush...On the bottom same scenario the bottom needs to be fly cut at the ends about 4" long
My buddy has a Mill, but the table isn't long enough to do the job...The cutting portion is only about 18"...He has a table vise mounted to the table...I have in my possession 2 table vises which are matched but not matched to his...Just for reference...
I don't know how to get what I want done on his mill
So
My other buddy has a large CNC Machine very heavy-duty platform that has the platform to hold the 2" x 2" tubing and is willing to fly cut...he has never attempted anything like this...we were thinking a few thousands at a time un till we got a 1" wide or larger swart down the middle for the linear rail to sit flush......Now we have to do this twice so the finished OVAL at the upper and lower ends has to be accurate...
One thought was to get a fly cutter with a 1/2" shank since that's all he can get into the spindle
Another thought we had was to get a 1/2" end mill and make numerous passes until we get the desired finish, we are seeking...
Thought's as to other options or any one of the methods won't work and this is why or on the side of good news anyone of the afore mentioned will work and rock on...
Anyway I go, I will have to get the desired tool for the job...
I don't think It has to be dead nut accurate like your professional machinist are capable of achieving but this will be a hobbyist CNC and allot of it will be made in garage and drilled perhaps with a drill press and holes laided out by hand... so hopefully you can see where I'm going with this...
Thanks
Paul
So
Thanks
Paul
