Not getting into the weeds with regards to tube sizing, it could be possible to fixture a tube such that the two pads are.machined first, then said pads are used as datums for the second setup where the full length pad is mowed. You would have to have sufficient wall thickness to account for any loss of material due to tube distortion along its length.
Be mindful of the standard tube tolerances for straightness and twist. Depending on the specific flavor of tube, they can be rather generous, so you may need to ask your vendor to cherry pick you a real good piece.
