A recent thread asked about tool options for cutting through the hard and abrasive outer skin on cast iron castings. And by extension this applies to mill scale. Big face mills were mentioned but the parts that were shown were smaller.
I went to have a look online with my new favorite home delivery supplier and found THIS THREE PIECE SET . Chuffed with my success with the 3 insert 1.25" face mill I bought about 6 months back and which has served well with prepping hot rolled stock a few times since I decided to order up this set to try out. The friendly Amazon guy dropped it off a couple of hours ago. It was a great excuse to put off some gardening.....
I used the 5/8 size to skim the bar shown. Yes there's swirl marks as one might expect. But my fingernail dragged over the surface in any direction feels nothing at all. Just a glass like smoothness.
I ran my first test at .015 DOC and 1400 RPM. Result was nice but a touch "cloudy" looking. Smooth to the finger nail though. I then ran at 1600 and now the finish had more of a shine to it. And needless to say I could traverse the cuts faster to keep a nice chip coming off the cut. For the 5/8 diameter 1600 worked out to 262 SFM. That's actually below the recommendation for mild steel by about 80SFM. So I might have to try the next speed up. But as it was I'm already pretty happy... but for one thing.
Note in picture 3 that I managed to chuck out part of the edge. This would be right where it was carving through the mill scale. I don't know if I did something wrong and caused a back drag or what. Or it might just be luck of the draw with the low cost import inserts. I'll get back to you all with that after some more testing. Sharp eyes might notice a deeper circle in the middle of the face on the test piece. I suspect that's where a piece of the carbide chunked out and got pulled around by the edge before being flipped away.
The close up of the insert face shows that the inserts are not simple triangle shapes. There's a small secondary skimming edge to aid with avoiding the usual wave like pattern that would occur with a simple round tip.
All in all I think I'm pretty happy with adding this trio of small flycutters, which is essentially what they are, to my milling ability. Especially if they avoid wear and tear on my other "proper" end mills for doing something as basic as skimming away the mill scale.
EDITED TO ADD- The vertical edge on the insert is not vertical. I made a set of three small vertical cuts along the one end with no X axis change. Just the table and traverse in and out on the Y. The result was a slight stair step. So these are not good for doing any vertical face skims. Very much small diameter fly cutters only for doing flat surfaces.
