I need a replacement belt for my KO Lee Cutter grinder. The one I have is getting very worn and need to replace it. I checked with McMaster but the one I got from them (orange) is too flexable and the motor torque really flexes and jumps off the flat pulleys easily.
flat belt source
You got the wrong stuff. You probably want the Buna-N with nylon core. Or the old leather type, which McM also has.
I do not know what the surface is like for that Buna-N belting. For polished pulleys, you want the shiny and almost sticky surface type. Or leather, hair side in. The belting I have on the Logan has the shiny surface, and grips well, like a barely damp hand on a shiny pole.CNC machines only go through the motions.
I have a lathe that used a flat belt and upgraded to the "future" with out a time machine as Bented suggested and it works fantastic. The one thing that I did was turn it inside out and then did not have to worry about cogs or grooves in the pulleys since the flat side grips really well.
Just another suggestion that works for me.
TX
Mr fixit for the family
Chris
Flat belts must be used with crowned pulleys, Machinists Handbook gives dimensions. Your motor needs to be looked at, it should not jump and flex.
There must be lots of sources of flat belts in the USA, in the UK, I have bought from Lathes UK.Last edited by old mart; 07-16-2022, 04:58 PM.
Originally posted by old mart View PostFlat belts must be used with crowned pulleys, Machinists Handbook gives dimensions. Your motor needs to be looked at, it should not jump and flex.
- Likes 1
