Moving an 8000 lb tractor
Originally posted by Captain K View PostI mean it probably won’t physically fit on the trailer. And it says under 10k. I’m thinking a 20 or 22 foot 14k trailer is probably a better choiceI just need one more tool,just one!
Originally posted by RB211 View PostI think a dual axel 16' deck trailer from Sunbelt and my friends F350 should do the trick. "Get me a Beer"
U-Haul does trailers. One way.
Are going to start growing beets or some other odd vegetable?? Cause if so.. I will stay tuned in...JR
If the distance is less than 50 miles, drive the tractor. No worries about overloading the trailer or whether or not the tractor will even fit. No chance of a load shift dropping the tractor onto the ground. It also will probably take the same amount of time to get the tractor to where you want it as loading and properly chaining the tractor, then reversing the operation at the other end isn't isn't instantaneous. Also no worries about the DOT fining you for overloading or improper tie downs.
I've done the load and haul for a smaller tractor and I've done the drive (100 miles one time).
+1 on longer, heavier trailer. Backhoes are LONG with both buckets lowered to the deck.
Son and I made a day trip to pick up OUR new Case 1175 last week.
Tractor was built around 78’, bought it from son of the guy who bought it new. I’ve always liked the look of these Cases but it’s the first one on the farm. During haying season we run out of mid size tractors to do anything else with, so I’m kinda excited to fix a few details and put it to work.
- Likes 2
Apologies if you already know this, but there should be a transit locking pin which locks the backhoe arm in the straight position. Make sure this is in place when its being hauled. Thers been more than one accident where a backhoe arm swung out on a corner and hit a vehicle coming the other way.'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
Ok, Sunbelt limits their trailers to 6500 lbs. I found a 7x22ft 14,000 lb trailer tilt back for 100$ for the day.
I'm not farming with this, although it is based on the Case 430 farm tractor, it clearly looks like an older farm tractor, the CK designates it as a industrial tractor and has the subframe mounted loader and backhoe, case model 23 attached, no 3 point. Front PTO drives the big hydraulic pump. I bought all the service manuals, parts catalogs to it. I love tractors from the 1960's, all were designed to be worked on and endlessly rebuilt to last forever. Engine has bore sleeves, etc...
