Originally posted by larry_g
View Post
Moving an 8000 lb tractor
Originally posted by RB211 View Post
Backup plan is a local mover at 150$ an hour. The distance alone makes this pricey.
Originally posted by SVS View PostHolding air is more important than tread on a backhoe. You aren’t going mudding with a
2wd. anyhow.Sole proprietor of Acme Buggy Whips Ltd.
Specialty products for beating dead horses.
- Likes 1
Originally posted by Beazld View Post
Holding air (or ballast?) is important. I ran a case backhoe back in the 70’s, a 580B IIRC, that had bald rear tires from running on pavement most of its life and it was sketchy when you had to take it in the dirt with some moisture in it. Back end slid around a lot and would have to use the hoe to get out of some areas due to lack of traction. Just saying…
I’m not criticizing RB’s purchase, but it’s an OLD backhoe. Numerous things could break that are unavailable or uneconomical to repair. I’d want to get some hours on the machine and feel good about it’s prospects before buying new tires that will add near zero productivity in good conditions. Would they help in mud? Some, of course, but it isn’t gonna set the world on fire either way.
That $4300 bargain could turn into a $10,000 paperweight in a heartbeat, but at least it would go to scrap yard with nice shoes.
- Likes 1
Originally posted by SVS View PostI’m not criticizing RB’s purchase, but it’s an OLD backhoe. Numerous things could break that are unavailable or uneconomical to repair. I’d want to get some hours on the machine and feel good about it’s prospects before buying new tires that will add near zero productivity in good conditions. Would they help in mud? Some, of course, but it isn’t gonna set the world on fire either way.
I was stupid and forgot bill of sale. This guy has worked for my business partner in the past, so some benefit of the doubt existed. Lesson learned.
Originally posted by tomato coupe View Post
Even with a bill of sale or a signed contract, you'd have to sue him to force him to go through with the sale. Hardly with the effort for a $4300 machine.
But you can also enjoin him from any OTHER sale pending resolution. That's more trouble for the seller than for you, assuming he really wants to sell it. (needs the money, etc).
Likely not worth it overall, unless for some reason you want THAT tractor.CNC machines only go through the motions.
I'm sure they are pricey, might put chains on them. Hopefully it's the less expensive size on the tractor. Came in two sizes, one is very common, the other is not. Just spent 580$ on new brake components for it.
- Likes 1
My buddy recently got a Case backhoe.
Not sure the year, but an older one.
The block on the diesel engine had a
huge blowout just above the oil pan rail.
Larger than a Coke can. It was all welded
back together and the engine ran well.
He said he was not afraid of it, as the welds
were not cracked or leaking at all. An old
repair that stood the test of time is apparently
nothing to worry about. He is an old tractor
puller guy, and he says the alloy in the old
Case parts is really good. More like steel than
cast iron. Aside from blowing an old hose once
and a while, he uses the heck out of it.
-DoozerDZER
Originally posted by RB211 View PostWe are pretty much settled on getting a Case Construction King, if not this one, another.
