Here's a picture of the fairly hard 1x6.5x12 "bench plate" I love using for an anvil like object for center punching items and doing letter and number stamping. Also shown is the hard rubber like pad I've been using for the anti skid and somewhat compliant pad to stop the plate from jumping around.
The issue is that one side of the pad is ribbed and the other has a fabric like texture. BOTH sides seem to encourage corrosion but the flat side is worse. I just cleaned up the bench top of some corrosion despite it being wet out with Fluid Film before laying the pad down. You can see the fresh swirl marks from using the flap disc. It lasted a good long while mind you. But still.......
So what I'm wondering is if any of you have any suggestions for a pad which will be firm but somewhat compliant for absorbing the energy so the plate doesn't bounce. But which will also not encourage corrosion of the steel top or steel plate?
One thought which occurs to me just before I hit the "Post" button is a carrier plate with four fairly large rubber grommets that acts as a spacer but also allows for some air circulation. I've got some grommets that are up around 1 to 1.25 diameter to fit into 16 gauge sheet. I'm open to any suggestions though.
