Originally posted by Bented
View Post
Looking for suggestions to avoid corrosion
Chilliwack BC, Canada
Lead is indeed a good thought for damping.
Same thing as any other material, though, for wicking. That's if there is ever water there, such as from condensation, or dripping soluble oil, etc. Must be water there, if you find rust.
Maybe get the luan to soak up some oil?CNC machines only go through the motions.
But I don't use that stuff around the bench block.
While I think sheet lead would work well I don't have any and have no idea where to find it easily. So I'll run with the UHMW PE for now. If I get more rust then I'll give a well treated bit of the luan plywood a try.
And for giggles I think I'll put a piece of clean degreased steel on that old rubber and see what happens. But in all these cases we're looking at some weeks out before there's any final answers.Chilliwack BC, Canada
